Is it blown!!
Username: Rwells
Atlanta, Georgia United States
Post Number: 44
Ive had 2 12" cvr's for about three months now and for about a week only one has been working right. the other one is not moving at all. when i have the music playing i can push down on the sub just about half a centimeter and it will start bumpin again and then it will sort of play a little but make a little noise where it sounds like something is rattling inside of it. Do you think its blown? i checked the wires and everything is good.
Username: Kyle_lowe
Post Number: 52
ggggg, doesnt sound good to me but i really am not the person to ask. i am just starting to understand the intricacies of the car audio world.
Username: Basshead86
Slowcala, FL The one that...
Post Number: 3018
sounds like a burnt VC to me or something.
Username: J_baby15
Kentucky
Post Number: 171
I had the same thing happen to my L7. I found a guy who will fix it for about $40 plus shipping, i can give you his address if you need it. He told me it was a common kicker problem. It's not blow tho, it can be fixed.
Post Number: 3020
There's that Kicker quality for ya!!! :-O
Username: Rwells
Post Number: 46
the sub actually sounds more like when where you will put your fingernail up to the sub when its hitting, and it makes a rattling noise. its actually playing now since i took it out and put it back in. and i think you could be right about the VC because one of the VC's, the insulation was sort of peeled back and in one place it looked like it was spliced. but at the end of the wire on the VC where it connected to the cone, it would flop around real easily instead of it being where it shouldn't move if you shook the sub up and down. sort of like it was coming out of the socket or somethan.
Username: J_baby15
Kentucky
Post Number: 173
Lol..thats why i jumped onto treo. Hopefully 2 15 SSIs wont disappoint me.
Username: Rwells
Post Number: 48
so is there a way i could replace the VC without sending it in or do you think its the VC or what?
Username: J_baby15
Kentucky
Post Number: 175
I'm not really sure what the actual problem is. I have no clue how to fix it myself.
Username: Young_james
Post Number: 1345
had that problem.........your sub is fried my friend.........Same as muddy said, your VC is shot
Username: Jmloughrey
Farmington, CT
Post Number: 1504
maybe one of your tinsel leads came off?
