HOT!!
Username: Mr_kebo
Albertville, Al USA
Post Number: 290
Im running a sub off of an eD NINE.2x and its getting pretty hot. Like to hot to touch but dosent cut off or anything.Its wired to 4ohms right. Is it normal for these amps to get that hot.
Username: Mr_kebo
Albertville, Al USA
Post Number: 291
BTW the sub in a 12" RE SE 2ohm DVC.And the amp does 600 watts briged@4ohms.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 510
that's the problem man! you have a dual 2 ohm voice coil and your amp is bridged, maybe you should run it stereo at 2 ohms, cuz most of the amps bridged are 4 ohms
Username: Rovin
Trinidad & T...
Post Number: 7486
2 chan amps r usually class A/B which r less effeicent than MONO amps & thus gives off alot more heat .....
long explanation >
http://www.wickedcases.com/caraudio/ampspecs.html
Username: Rovin
Trinidad & T...
Post Number: 7487
wrong link above - my bad
its
http://www.wickedcases.com/caraudio/amplifiers.html
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 768
theres no problem with him havin a dual 2 ohm sub, thats perfect, sub VC's wired in series gives u a 4 ohm load, which is wut his amp is stable to in bridged mode. and it gives out 600rms @4 ohms, which is exactly wut his sub needs. like rovin said, class A/B amps give off alot of heat. if u are really worried about, i guess u can give eD a call, or wutever they request u do for customer service.
Post Number: 769
did u get ur SE customized?? becuz they dont come with dual 2 ohm coils standard. they usually come with dual 4 ohm coils. i know u can get them to make it with diff VC configs, but just wondering if u know for sure that ur sub is dual 2 ohm.
Username: Mr_kebo
Albertville, Al USA
Post Number: 294
Yea its dual 2 cause i asked for that when i bought the sub cause i wanted to run this amp.
