HIFONICS 1600W BRUTUS BXi1606D? To much power for these subs?
Username: Will_1985
Washington, DC USA
I plan on buying either a R-type, Comp VR, L7
or a Adrenaline. I already have a HIFONICS 1600W BRUTUS BXi1606D, but I need to know which sub is the best match for my amp and which setup will hit the hardest. I plan on getting two 12's I care more about SLP then SQ and I listen to hiphop.
Thanks
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1812
should be fine for the Typr-R's or the L7's. i don't know about the Comp VR's or Adrenaline though. if you just want SPL, go with the L7's
Username: Themax99se
Post Number: 9
I have the same amp hooked up to Two Type R 12's. Sounds great! I recently also go a pair of Kicker CVR 12's... The Alpines are the way to go!!
However the two Kicker L7's are probably going to beat out the Type R's on SPL, and they can handle more than the R's. Comps 400RMS, Type R 400RMS, Kicker L7 is what 600-700RMS.
I think the Type R's handle the power from the Hifonics BXi1606d amp just fine though. How do you like the amp? What have to tried it with?
