After careful consideration I have my new system
Username: Loudon
Post Number: 332
After talking it over with Mr. Longo for quite sometime ... I have decided on my new system
Source Unit - Pioneer Avic -n3 or Alpine Ivad-901
2 12" Kicker CVX Dual 2 ohms
Kicker zx1500.1 - since the kicker amps are overrated ... ill be putting out over 1500 watts
slot ported box ... havent decided on where I should set the box too .. if you guys have an opinions ...
I also need an ho alternator ... I have emailed a couple places for my focus hatch ... but no responses .. so let me know if ne one knows a balpark price .. i already have a yellowtop ..
interior speakers - i stil need to figure out what i want to do with those any suggestions ... please let me know ... also a 4 channel amp ... around 100x4 ... they are 6x8 speakers ... but im gonna plate up the front for 6 1/2 comps
any suggestions... opinions ... please feel free to give me your input
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 925
source unit: both are great
subs: i like the CVXs. give us a good review on them
box: i would port the box to 32 hz.
alternator: i would do 175-200amp. you wouldnt need anything more than that.
speakers: FRONT STAGE! depending on how much you want to spend i would go for a nice set of DLS, focal, dynaudio...something like that.
speaker amp: maybe a zx550.2 or zx450.2. its pretty much the more power the better for those brands of speakers.
for the speakers if you give us a price range we can send you in the right direction but you really need to listen to them before you get them.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1003
wouldn't 2 dual 2 ohm subs wire down to 2 ohm or .5ohm? isnt the amp 1 ohmstable?
St. Louis, MO
Post Number: 930
thats a good point.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3925
Username: Rovin
Trinidad & T...
Post Number: 7436
my alpine F545 4 chan amp does a gr8 job .....
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6564
that amp is 2ohm stable so he had it right, all of kickers new amps are 2ohm stable i believe
Username: Loudon
Post Number: 335
yea all of themn are 2 ohm stable ... except for the 2500.1 ...
Username: James1115
Ct
Post Number: 5683
hey Mike what can you get the Polk sr6500's for?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1004
what ohm is the new 2500? i dont see it on the website.
