Sql sub under $400
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 76
i want either 1 15" or 2 12" sql subs, what are some choices.........need to be under 400$ though
Username: Sw9152
Michigan
Post Number: 424
eclispe titanium 15" is $355 at electronicgiant.com. the rms rating is per vc so the actual rms is NOT 750 it IS 1500. i got one and i love it. also you could look at getting 2 ascendant audio arsenals you can get 12" on sale for 160 ea. for a little while because you have to pre-order.
Username: Adddisorder
Post Number: 162
or look into the AA havoc supposed to be great spl and sq i think its like 425 though should be worth it
Post Number: 77
what about a 15" memphis mojo.....are they ne good?
Post Number: 78
bump
Post Number: 79
how are alpine type x's
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6630
no^^^
Crystal comp x
Post Number: 83
where can i find them
Post Number: 85
bump
Username: Jkidder
Spring hill, Florida Usa
Post Number: 103
www.crystalmobilesound.com
Username: Basshead86
Slowcala, FL The one that...
Post Number: 2960
Ascendant Audio Arsenal $220 a piece....well worth it IMO.:-)
Username: Blk02ss
Post Number: 48
crystal audios website says the comp 12 is 700 watts rms and the comp 15 is 800 watts rms... but every other site says the 12 is 600 and the 15 is 700... which is it?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2661
doesnt really matter. give it a clean 1kw
