Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1989 Registered: Dec-05 | maybe i will get more looks here since i got nothing in speaker section ... what are some good components for me to put up front ? they need to be 5.25 and under $300 . and i got 2 10'' alpine type e's on 600 watts if that helps |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1991 Registered: Dec-05 | http://sonicelectronix.com/cat_73.html are any of these sets under $250 any good ? |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1384 Registered: Jun-05 | i would say no but then again i dont know anything about components so dont take my word for it all i know is i wouldnt buy them |
Bronze Member Username: KillswitchjdPost Number: 45 Registered: Apr-06 | infnity reference 5 1/4" components are good... my 2 cents |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1992 Registered: Dec-05 | http://sonicelectronix.com/item_1742.html what about these |
Gold Member Username: CenusHicksville, Ohio Usa Post Number: 1644 Registered: Jan-05 | what are you gonna power them with. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1993 Registered: Dec-05 | not sure yet ... gonna see what some good speakers are then get me an amp |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1994 Registered: Dec-05 | http://www.woofersetc.com/index.cfm?currentpage=3&fuseaction=category.display&ca tegory_id=39&sort=high what about these ? pick me out a set from this lineup |
Gold Member Username: CenusHicksville, Ohio Usa Post Number: 1647 Registered: Jan-05 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1085 i hear good things abot cdt, http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1155 focal http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1150 focal heres some ideas, im not an expert at componet speakers but i here good things about cdt and focal on here. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1995 Registered: Dec-05 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1155 focal i like these .. and im like you ive heard good things about them |
Gold Member Username: Jonathan_fGA USA Post Number: 5943 Registered: May-04 | Focal Polyglass components aren't that great. Focals high end stuff is nice, low end stuff sucks. I'd save my money just a touch more and get those PG Ti Elite components-they're built and designed by Morel. Excellent components. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1997 Registered: Dec-05 | thanks johnathan .. what about boston ? do they have any sets nice under $300 ? |
Gold Member Username: Jonathan_fGA USA Post Number: 5944 Registered: May-04 | Boston sets are nice-the newer Pro50 components should suit you. I wouldn't go with anything lower from them personally, though. Bostons tend to have a characteristic sound the people either love or hate, if you have a nearby Tweeter, Hifi-Buys,or other subsidiary try to go listen to a set before you jump. Others in that price range worth considering are JL XRs and the MB Quart Premiums. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1999 Registered: Dec-05 | i figured the xr's would be nice .. but chad said he didnt like them .. but then again everyone has different tastes , i may love them |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2001 Registered: Dec-05 | i was wanting to go with some jl xr's and maybe 2 12'' w3v3's .. would that be a nice setup for a single cab truck > |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2003 Registered: Dec-05 | johnathan between the mb quarts and xr's which would be better ? |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 3731 Registered: Oct-05 | casey if you want the xr's then i suggest you getting the 3 ways. i've heard the xr 3 ways and they sound much better and different then the xr 2 ways. that is if you know how to do a good job of installing. i wanted 3 ways one time and jonathan told me they are hard to setup so i would be better off with just the 2 way. |
Gold Member Username: Jonathan_fGA USA Post Number: 5947 Registered: May-04 | Vehicle dependant. 3 ways are more difficult to implement in certain vehicle types. Generally, if you can't/don't want to do kick panels, you'll probably do better with 2 ways. The XRs have a rather higher crossover frequency to the midrange from the midbass driver, for that reason you'll want to keep them close together. 3 ways are nicer if setup correctly, though. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2004 Registered: Dec-05 | so if im going to put them in the doors 2 ways are better ? |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2005 Registered: Dec-05 | http://www.madisound.com/cgi-bin/index.cgi?cart_id=2502849.27618&pid=2129 someone suggested these to me .. ive never heard of them and they seem kinda cheap to me |
Gold Member Username: Jonathan_fGA USA Post Number: 5948 Registered: May-04 | I posted that for somebody a while back Vifa makes great raw drivers-it'd be every bit as good as stuff costing much more than that. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2006 Registered: Dec-05 | so they would sound just as nice as some jl xr's ? |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2010 Registered: Dec-05 | anyone ? |
