How to know how much power an amp produce
Username: Extrmndor3
Chicago, Ill Us
Post Number: 476
can some one tell me how cani test an amp and see how much watts is pushing in some load???
Username: Ctmike
Ct.
Post Number: 283
you mean getting it benched? just take it to a audio store and have it benched, usually costs like $5-10. thats the only way i know of.
Chicago, Ill Us
Post Number: 479
man that sucks is there a w ay to bench it wit a voltimeter or somenthing
Username: B101
Queen City, NC USA
Post Number: 2412
put the meter to a ac voltage, then burp the amp, measure the ac voltage from the speaker outputs... If u have a current clamp u can measure the current.. or if u have a good meter, set it on high current input unfused, then series the meter with either postive or negative of the speaker wire, record the current flow at burp also.. now u should have the voltage and current recorded.. always remember u measure current in series..
divide your voltage by your current see what the resistance is at burp.. V/I=R
P=V^2/R that will give you your power output..
Username: B101
Queen City, NC USA
Post Number: 2413
bump.. :-)
