Damaged type R
Los Angeles, CA USA
Post Number: 3548
my friend had a pc in the trunk and the corner of the pc ripped on of his type R. its not that wide but it looks pretty deep. we unplugged the sub for now so it won't rip any bigger. is there anything he can use to patch that up?
Username: Gangstaplayer
Gangstaville chicago
Post Number: 37
try ductape jk you silicone that might help but it will effect sound quality
Username: Rovin
Trinidad & T...
Post Number: 7194
thats terrible man !
go to any hardware store & buy a simple 2 part EPOXY - that sh!t does not let go once apply properly .....
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 57
I REPAIRED ONE OF MY SUBS USING SUPERGLUE...THE RIP WAS ON THE FOAM SURROUND...I PUT SOME SUPERGLUE GEL ON IT, LET IT SIT OVERNITE, AND WHEN I HOOKED EVERYTHING UP...SOUNDED GOOD....NOT SAYING ITS THE BEST WAY, OR THAT IT WILL WORK EVERY TIME, BUT IT WORKED FOR ME .
Los Angeles, CA USA
Post Number: 3556
thanks guys for the responses. all your ideas sound great. let me get a picture of the damage tomorow and i will post it here. after that you guys can tell me the best way i can take care of it.
Post Number: 59
??? IT SAYS 5 BUT I ONLY SEE 3
