Subwoofer recommendation
Username: Elier99
I have 2 JL 10 W7 on a custom ported enclosure tuned to 34Hz powered with a crossfire 2000D. Im planning on changing the two 10" subs with a single 12". I was thinking on a Orion H2 12.4 or maybe an Audiobahn Immortal quad2. What you recommend me?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1585
lets see go from jl to orion or audiobum, umm if you did that you would be the STUPIDEST person alive, i'd say look into the new re xxx.
Username: Night_mirage
AmmanJordan
Post Number: 215
what ???
you want change W7 ? are you stupid ?
as Dustin said RE XXX .
But why you want change your w7's ??
Username: Elier99
The reason is I had be using the W7 with the crossfire at 1.5 ohms for about 2 years and the excess of power has damaged them. I could replace them with two 12" W7 but it would be too expensive.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 829
15' treo SSi...you would need a 15' in order to maintain the SPL.
or like they said an XXX.
Username: Ton
Post Number: 47
don't go with audiobahn, stay with JL Audio
