Will they handle it...?
Username: Killer44
Ontario Canada
Post Number: 483
http://cgi.ebay.ca/Audiobahn-A8002T-Amp-800-Watt-RMS-1600-Watt-Peak_W0QQitemZ970 6322781QQcategoryZ48597QQrdZ1QQcmdZViewItem
my subs are 2 kicker cvr 10's they are dvc4ohm (300rms each), or please recommend another good cheap amp please (not from ikesound, problems with shipping costs to canada, it will be too much with border costs...) thanx in advance
Username: Matt12490
Benicia, California USA
Post Number: 592
i think that amp would be fine. but whats your budget?
Username: Killer44
Ontario Canada
Post Number: 484
around 250$ cdn and i want to stick with buying something off ebay...or a online store based in canada so i dont have to deal with duty and custom charges....
Username: Killer44
Ontario Canada
Post Number: 485
anyone else...is the amp to powerful i know audiobahn sometimes overrates but its 100rms over for each sub and i heard the A800OT/A8002T were theyre best amps and figurd they might not be overrated....?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1575
cvr's are good subs, they can take more then their rated, i've seen a 12 take 600wrms without a problem, so im sure the 50 or so watts more isn't gonna hurt.
Username: Killer44
Ontario Canada
Post Number: 486
thanx alot dustin
