Is it legal to drive without a trunk lid????
Username: Kevin420
Gilbert, Az USA
Why is it the bass in my system really rocks harder when the trunk is open. I have like a70/30 split rear seat, with the 30% fold down seat down, trunk closed, still is nothing compared to having it open. Is there different mounting techniques to fix this, or just another problem of poor car acoustics????
Username: Pelona
California
Post Number: 1166
probly cuz u have ur subs facing forward. when u have ur subs facing forward and u open the trunk u get more bass. cuz the bass waves that bounce off the seat dont cancel out the other bass waves that go through the seat
Username: B101
Queen City, NC USA
Post Number: 2222
Username: Solacedagony
New Jersey US
Post Number: 872
Porting the airspace from the trunk into the car may help out too.
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 529
Read b4 you speak. he said he leaves one of his seats down.
New Jersey US
Post Number: 874
Oops, didn't see that you had your seat down.
In that case, cracking yoru window should have the same effect. And like Freddy said, try experimenting with different box positions.
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 531
I would try up firing, rear firing, or down firing and find the one you like the best.
Username: Talon_es93
Post Number: 154
i've had best results with rear firing unless if its a bandpass box... i think rear firing makes a BIG difference compared to front
Username: Safe_cracker
Chicago, IL US
Post Number: 720
It is just a cancellation wave, box is probably a prefab and the back is probably flexing releasing a wave of energy. Add some Dynamat to the trunk area and turn it around. Place the box as far back as you can without blocking anything this will give it less to bounce off of. Polo.. :-)
