MELT Down!!!!!!!!!!
Username: Bino317
Post Number: 11
Heres the problem, i have an 2000watt a ch amp, two dvc 1000 watt speakers. 8 gauge power cable, wit an 100 amp ANL fuse,a 500k farad Cap. and an extra battery, my system bumps, its just that when i turn it up, my radio cuts off and on. and then if i let it continue to play, my subs just cut off. first it kept blowing my battery fuse, so i got the 100 amp,and a 4 gauge power cable so now either the fuses in the amp melts and blows or they just cut off. i'm tired of going back to my trunk to check if somethings burnt up. someone please tell me whats wrong.
Username: Young_james
Post Number: 1129
sounds like your clipping it big time. Post what kind of equipment you have. That's probably all max powering ratings. Also, how high up do you have your gain set? Do you lights on your car dim when you turn it up? Do you subs distort? Bit more info and we should be able to help :-)
Username: Bino317
Post Number: 20
I have a Lanzar 268 2 ch (500 x 2 rms)2000watt 2 ohm stero stable amp, I have two Visonik 12" dvc 1000 watt speakers 4 ohm, I have an extra battery ran to my car battery 4 ga power wire going into a 100 amp ANL fuse, back to an 500k Farad Cap, 16 ga speaker wire.I have the spreakers ran in parallel and are briged. the gain is set two notches before max. My interior lights dim a lil to the beat. the subs dont distort, its just the fuses blow in the amp( two 30 amp fuses) when i try to crank it up(on a 32 max scale i get it turned up to 20).
