Fuse keeps going
Username: Bakerj72
Regina, Saskatchewan Canada
Post Number: 113
00 integra - 500/1 - 10w7 - 9835 - At high volumes i blow the backup radio fuse (under the hood)7.5A... how do i prevent this??????
Username: Goatin
U.S.A
Post Number: 699
I hope you did not connect the continuous power on your HU strait to the battery...
If that is what you are asking just plug it in to the continuous wire place on your wireing harness.
Username: Nemen
Post Number: 705
yeah do you have it like that like raven said?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 910
You have an aftermarket deck right? And you probably used a wiring kit to install the deck. Could very well be that the aftermarket deck uses more current than the factory one. Especially if you are running speakers off of the deck without an amplifier. What size of fuse does the new deck require? I personally would replace the fuse under the hood with the size recommended by Alpine.
Username: Shepyjay
Ont Canada
Post Number: 109
justin just change the fuse to a 10 amp youll be fine with that
