Silver Member Username: Night_mirageAmmanJordan Post Number: 209 Registered: Jan-06 | I draw these boxes and i know i'm not that much in drowing . i just want to know what is the different between these ported . and saled and the other one witch i don't know what is it ?? |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... USA duh Post Number: 2064 Registered: Nov-04 | if i understood it right, which is describing the diff designs then here it goes. First one: that is a ported box, it just uses round ports. Second one: Is sealed but its inverted mounted also known as "Phat mounted" 1st ported: just a box with seperate chambers and a square port 2nd ported: box that shares a port |
Silver Member Username: Night_mirageAmmanJordan Post Number: 212 Registered: Jan-06 | Thanks but what is the different between voices . and what is better for two CVR 12" |
Silver Member Username: Night_mirageAmmanJordan Post Number: 213 Registered: Jan-06 | please guys i need to know what should i make ? |
Gold Member Username: RovinTrinidad & T... Post Number: 6885 Registered: Jul-05 | http://www.diysubwoofers.org/ |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11405 Registered: Dec-03 | what Rovin said and... http://www.glasswolf.net/caraudio/inverted.html |
