Are pioneer Premiers a good choice??
Username: Extremesound1
Coventry, RI United states
Post Number: 40
i want to get this pioneer premier is it good or bad you can click to enlarge the image on the website. i think it is a most definate buy to get
2076_4041_64496605%2C00.html,http://www.pioneerelectronics.com/pna/product/detai l/0,,2076_4041_64496605,00.html
Username: Tjmutlow
Post Number: 1707
link does not work but the premier lines are good radios.
Username: Mrbass
Long beach, California United state
Post Number: 17
check this outUpload
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1493
^ thats the 2006 Pioneer DEH-P6800MP. not a bad unit, but it only has 2.2V pre outs...
i'm still waiting on my 7800, a step above that one. very simular to the 680 premier.
Username: Rustysurfer916
Oviedo, FL
Post Number: 99
from what ive herd you dont use more than like 2 volts so the primier ones that put out like 6 volts is just a waist.
Username: Slaya
Post Number: 22
if you're spending 200$ on a head unit then maybe thats true considering the rest of your system is budget aswell.
if you compete in events and are using a 600$ "pioneer premier" as matt stated, then NO it's not a waste, and does make a difference.
Stockbridge, GA USA
Post Number: 1503
the pre out voltage is the only thing you can control. the higher the signal strength, the less work the amplifier has to do and the better the sound will be. it will make a big difference.
