Gold Member Username: Sploosh56
Ohio
Post Number: 1214 Registered: May-04
Posted on Anyone use these for their front speakers? Do they make a difference good or bad? |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1449 Registered: Feb-05
Posted on i have them on mine, but have the back/bottoms cut out so i only have a cover over the top to keep water away. lol honestly, they will limit the air space and kill bass responce. i wouldn't use them for anything other then what i mentioned above. |
Ohio
Post Number: 1218 Registered: May-04
Posted on ok thanks |
New member Username: Van_man
Post Number: 2 Registered: Mar-06
Posted on I have hard plastic baffles and it def helps out the bass on 6x9s |
