>:-( HELP! New Alt problems
Username: Montecarlos11
Louisville, KY USA
Post Number: 16
Okay i got my new alternator put in like 2 weeks ago now. It is a 200 amp alternator and it brand new. And my headlights are still dimming, and pretty bad. All i am running is a pair of 12" xplods and a 800W peak (if that) kenwood amp. Also these cut out at random times in songs and come back after awhile. Are these two problems related. Maybe just a bad ground some where, or are my problems much bigger?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6279
did u upgrade ur big 3 as well???
Username: Fandim
Reno, Nevada United State...
Post Number: 817
Check all your grounds, for sure.
Also, have you upgraded your big 3? This is critical when dealing with a HO alternator.
Louisville, KY USA
Post Number: 18
I upgraded my wires to 4 gauge, for both grounding and power to my alternator. But i am not too sure what the big three are. Please fill me in. I am so annoyed with my disco ball car.
Username: Fandim
Post Number: 818
Alternator to battery.
Battery to Chassis.
Engine to Chassis.
Louisville, KY USA
Post Number: 19
Where would i ground the engine to chassis?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1490
anywhere you can pretty much.
Louisville, KY USA
Post Number: 20
okay i tried it and its still doing the same thing. Also i noticed a high pitched squealing noise coming from the alternator when i turned my subs up.
Username: B101
Queen City, NC USA
Post Number: 2060
Do your entire big 3 all over again!! Also run your power on 1 side of the car, and rcas to the other side!
Louisville, KY USA
Post Number: 21
did that with the power and rcas already when me and my bud hooked it up
