Would a jbl 600,1 be enough power?
Username: Teg24
Post Number: 23
would a jbl bp 600.1 be enough power to power 2 12w3s 4ohm dvc???
Cron
Well, w3's are 250 to 300 watt rms and that amp would put 300 watts rms to each of them. I would say it was perfect.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2539
yup
good match for a sealed box solution
if you go ported, go to partsexpress.com, and buy $20 FMOD 20Hz high-pass subsonic filters for the amp to prevent over-extension from the subs.
also grab a couple Y splitters to send signal to all 4 of the JBL's RCA inputs.
makes for a stronger signal to the amp and better output
