85 Jimmy Speakers
Username: Jerome
Post Number: 8
i want to change out the Front speakers(the ones thats on the dash)
I think its 4X10 but im not sure. But i want to put in some 6X9's any suggests?(I dont want to put in a addation boxes for the 6x9's
Also i dont have any rear speakers(thats how i got the truck)
Username: Nypdlapd
Post Number: 102
the front on old jimmys are usally 5.25-6 inchs
Hope this helps!!
Username: Homegrowncam
Watauga, TX United States
Post Number: 247
I believe they are 4x6s.
Username: Mrmikelazott
Independence, Oregon
Post Number: 86
how much is ure budget. you should get some 6.5 components. what size are your rear speakers?
Username: Jerome
Post Number: 11
well i took out the speakers and they look like small 6x9's so im guessing there 4x6's and far as a budget im not sure nothing to high. I was thinking about throwing some pioneer ones in there.
