Ford explorer 96
Username: Extrmndor3
Chicago, Ill Us
Post Number: 82
hey guys can you tellme where the factory amp of a ford 96 explorer xlt with premium sound thanks
Username: Rideredder
Cornell, IL USA
Post Number: 250
Passenger side, in the back, where the sub is. You have to take the sub enclosure out before you can see it, I think. But, you will have to take the whole side plastic off if you want to take it out. And you will probably break all of the clips that hold the grill on.
