New member Username: JboyPost Number: 2 Registered: Feb-06 | When i finished installing the amp and tucked the wires, i tryed to turn on my truck (1990 chevy astro)and it started to turn over then it would cut off.When i took off the power wire for the amp and reconnected the battery wire it started!!WHAT IS THE PROBLEM!!! PLZ HELP |
Gold Member Username: James1115Ct Post Number: 5162 Registered: Dec-04 | sounds like a bad connection. I would put teh power wire back on and make sure your pos connection to the battery itself is solid. |
Silver Member Username: Matt12490Benicia, California Post Number: 408 Registered: May-05 | what is your amp? |
New member Username: JboyPost Number: 3 Registered: Feb-06 | 340 watt (dual 2/1 channel) 25 amp fuse |
New member Username: JboyPost Number: 4 Registered: Feb-06 | This is the amp: * PWM MOSFET power supply * 2 Ohm stable stereo operation * Bi-polar output transistors * Class AB output design * Stereo/bridged simultaneous operation * Bridgeable operation * Extruded aluminum heatsink * Barrier strip connection terminals * Side mounted controls * Auto-reset thermal overload protection * Speaker short circuit protection * DC voltage offset protection * Reverse polarity protection * Bi-color LED status indicator * Low level inputs (RCA) * High level inputs (speaker wire) * Variable input level control * Selectable crossover * (high pass/low pass/full range) * 12dB/Octave crossover slope * 12dB Variable bass boost |
Bronze Member Username: ErgodynePost Number: 31 Registered: Feb-06 | or would this be from a bad amplifier ground?? |
New member Username: JboyPost Number: 6 Registered: Feb-06 | YES THANK YOU IT WAS THE GROUND!!THANK YOU!! |
Silver Member Username: Goose5714Post Number: 195 Registered: Feb-06 | Lol, i was hoping he was gonna say that he couldn't get anything electrical to work, then i coulda made fun of him for doing the same thing i did, not rehooking up the batt. ground connection, i spent 20 frickin minutes trying to figure out what was wrong when i installed my first system, and then i realized i never rehooked the ground wire for my batt., damn did i feel stoopid. |
Bronze Member Username: ShepyjayOnt Canada Post Number: 17 Registered: Feb-06 | lol@josh every beginner does it |
