Will this work and sound pretty good??
Username: Thomas_g
NM
Post Number: 59
Sup ppl just wondering if i got an Alpine type R with the amp i got now if it would sound alright for now till i get a better amp. I got a Power Acoustik 980 watt amp 560 watts rms in bridged mode. I figured i could put the sub in bridged even if its only 500 rms cuz ppl say Power Acoustik is over rated. So do you people think it will still sound pretty good?? And wut should i buy the dual 2 or 4 ohm sub?? The amp in bridged could handle 4 ohm. Thanx for all the help....
Username: Tjmutlow
Post Number: 1504
you will want the dual 2 sub to run it bridged, and if your going to use only 1 sub, then you can get a 1ohm stable amp to push it.
Username: Caraudiofanatic
Post Number: 36
yeah like ty said. run it down to 1 ohm and that thing will pound to hell. my buddy had a set of 12" ALPINE type r's with a mb quart 1000 watt amp. and man did they hit.
Username: N2audio
Lawrence, Ks USA
Post Number: 634
You can't run a PA 980/2 amp at 1 ohm. It would be over quickly. The dual 2 would allow the amp to be bridged with the sub coils in series for 4 ohms mono.
