Lowpass
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 94
If your lp filter doesn't go below 35Hz and doesn't have a sub sonic filter, can you amp still put out below the lp, or will it cut it off?
Username: Pelona
Post Number: 690
if you have a lp and a ssf on then it will only put out the hz between them.
if you only have the lp on then it will play everything below that.
Username: Blainew
Post Number: 984
it will still go below 35 hz..just not above, as pelon said
Username: Jbump
Post Number: 112
could i get a xover that has a ssf on it and use that?
