Can you use any wire for a ground cable?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1029
color - yes, just insallation, just remember which is which if you use the same colors
type - yes, but it is best to use an oxygen free, multi strand wire thats meant to be used in car audio to keep interference out and corrosion down. also, it is a lot easier to deal with since its a lot more flexable then solid wire.
is that what you were wanting to know, or did i miss something?? question isn't specific.
I think that is pretty much what I wanted to know, so you could use a bit of old speaker wire as-long as you connect it to a bare bit of metal on the car?
Thanks for the help
Username: Blainew
Post Number: 963
the ground wire needs to be the same exact size as your power wire
Username: Rovin
Trinidad & T...
Post Number: 5662
Also ground wire is recommended 2 be 3ft maximum in lenght - preferably shorter though .....
Nanbakat
Speaker wire won't work as a ground wire because the gauge is too small. Unless, of course, you like having a fireworks show in your back seat or trunk.
Oxygen-free wire is important only for speaker-wire. It is irrelevant for power and ground wire applications. You will pay more for no discernable improvement in function.
Stockbridge, GA USA
Post Number: 1043
yeah, you'd melt speaker wire because it too small a gauge to handle the current.
Username: N2audio
Lawrence, Ks USA
Post Number: 589
"Oxygen-free wire is important only for speaker-wire."
Actually it's not important for anything in car audio. OFC has it's uses, but they exist in industrial applications, not in your car. It's an all-out marketing term.
Username: Lewass
Bloomfield Hills, MI USA
Post Number: 103
I can't believe nobody mentioned this yet:
The ground has to be as big as, if not bigger than the power!!!!!!!!
You could use speaker wire if you had large enough gauge.
Remember the concept behind a ground. It has to be able to take 100% of the power and redirect it out of the amp in a split second if needed. So whatever your power wire is, just make sure your ground wire could "beat up" your power wire in a fight. In electrical terms, this means, equal gauge or bigger (smaller gauge # = thicker wire), and much shorter in length.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1978
lewass, sorry to bust your bubble but some1 already mentioned that. read blaine's post lol.
