New member Username: MarkysparkyHobart, Tas Australia Post Number: 4 Registered: Feb-06 | looking at getting SONY XPLOD XM-1502SX AMPLIFIER - 2 x 300W MAX RMS - AMP 2 CH BRIDGEABLE BASS BOOST ADJST LOW / HIGH PASS FILTER to put on 12inch 4 ohm 1200watt speaker and bridge it but might put a seat of 300 watt speakers on other channel can i still bridge sub will these system setup be ok ???? need to no soon bidding ends in 5 hours thank mark |
New member Username: QwerPost Number: 1 Registered: Feb-06 | SONY RULES |
New member Username: QwerPost Number: 2 Registered: Feb-06 | i have all sony |
New member Username: QwerPost Number: 3 Registered: Feb-06 | hook them aalll up to the amp |
New member Username: QwerPost Number: 4 Registered: Feb-06 | I HATE YOU |
Anonymous | better then you, you are a fu.ckin idiot |
Bronze Member Username: QwerPost Number: 11 Registered: Feb-06 | SONY RULES |
New member Username: Logan__tillePost Number: 3 Registered: Feb-06 | SONY SUX |
Silver Member Username: CadillacdbHouston , TX Post Number: 525 Registered: Aug-05 | DO NOt I repeat DO not Bid on That stuff,, Please inform us of the amount you have to spend an we will point you in a better direction |
New member Username: MarkysparkyHobart, Tas Australia Post Number: 5 Registered: Feb-06 | ok no worries well only at the most 200 bucks looking at spending and just wont to bridge 4 ohm 1200 watt sub and hook up some 300 watt 6x9 3 way speakers to it as well . is it worth putting speakers on amp or just thru cd ??? what amp do u reakon u can get me or reacomend thanks regards mark |
New member Username: MarkysparkyHobart, Tas Australia Post Number: 6 Registered: Feb-06 | so yeah really just a amp in the 200 250 range that will go work good with my system |
New member Username: MarkysparkyHobart, Tas Australia Post Number: 7 Registered: Feb-06 | i have not brought the sub yet so if no any good deals or you can hook me up with somethink on a 12 inch sub with a good amp looking at about the $300 -$350AUS so about $250US dollars range that be great, regards Mark |
Anonymous | SONY IS ONLY SELLING A FN NAME.....DUDE GO WITH A BRAND THATS NOT SELLING THEIR NAME AND ONLY THEIR WATTAGE....LOL...f*** sonY. |
Anonymous | SONY SUCKS, IT REALLY REALY SUCKS!! |
Silver Member Username: CadillacdbHouston , TX Post Number: 528 Registered: Aug-05 | if you have 250 i would say buy a single type R 12 an a Viper amp an when you get more money buy some good components an if the single 12 isnt enough bass for you, you can always buy another one of those amps an subs to add to the ones u already have http://ikesound.com/product-product_id/2426 http://cgi.ebay.com/ALPINE-SWR-1222D-Type-R-12-DVC-2ohm-Subwoofer-Sub-1500W_W0QQ itemZ5866154750QQcategoryZ18803QQrdZ1QQcmdZViewItem |
Silver Member Username: CadillacdbHouston , TX Post Number: 529 Registered: Aug-05 | Sorry that i dont have many options for you but 250 is a really smalll budget an that single sub an amp would blow the sony stuff you were talking about out of the water |
Silver Member Username: Goose5714Post Number: 138 Registered: Feb-06 | I'll sell you my 2 infinity 12's a sealed box for em' and my alpine amp for pretty cheap if interested aim on goose5741 or email at goose5741@aol.com |
New member Username: MarkysparkyHobart, Tas Australia Post Number: 8 Registered: Feb-06 | ive only got a single cab ute so can only fit 1 sub in the middleof front seats so wont be able to get 2 in also ok to put 300 watt spekers thru head unit of cd player |
Bronze Member Username: ErgodynePost Number: 27 Registered: Feb-06 | Mark, your best bet would be to go to www.Ikesound.com get the Viper amp and an Alpine 12" Type R. (To everyone else out there) for something like this would a Type R be better or maybe a Kicker CVR? |
