What do you guys use to keep from rattling
Username: Pasqual1320
Post Number: 37
Is there a secret?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5617
edead v 3
Username: Redliner
Wilmington, Ma
Post Number: 753
i got 3 gallons of that stuff from that sale the otha day chauncey do you think it will be enough for a car or will i need more
Username: Redliner
Wilmington, Ma
Post Number: 755
bump since it didnt
Username: Terry6405
Sullivan, IN US
Post Number: 303
hes right, i used it, really blue, worked good though, but i think chauncey got confused and painted the outside of his truck with it
https://www.ecoustics.com/electronics/forum/system-showcase/173436.html
Post Number: 5624
3 gallons should be enuff, do u have a strong blow dryer
Los Angeles, CA USA
Post Number: 2446
i use edead v1se. its works great.
Username: Terry6405
Sullivan, IN US
Post Number: 306
i just left my car on with the heat full blast and it was good
Post Number: 5626
lol^^^That would work 2
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 131
What would you say is the best stuff for the price?
Username: Pelona
Post Number: 635
hey, does anyone know if you can install dynamat easily yourself?
Post Number: 5628
edead v1se, check it out on ebay,
http://cgi.ebay.com/10Sq-Ft-eDead-v1SE-Sound-Deadening_W0QQitemZ5855497861QQcate goryZ67760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Yukhui
Post Number: 133
edead v1se vs. edead v3? Which dampens rattles better and adds more bass?
Los Angeles, CA USA
Post Number: 2447
v3 works better cause you could get those into the cracks since they are liquid. neither of those will add more bass.
Username: Terry6405
Sullivan, IN US
Post Number: 313
well i wouldnt say that it doesnt add bass, it obviously wont straight up get more power to your subs but is creates an acustical harmany in your vehicle that creates the illusion of louder bass when, in actuality, is only sounds cleaner without rattling, you will probably be more likely to turn it up louder because it sounds better too
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11164
lizardskin and eDead v3, secondskin, mat (dynamat, etc) and expanding spray foam.
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 622
Pelon, dynamat does install easily all you have to do is let it heat up then roll it on or just use your hands. I have had a lot of success w/ dynamat and i have always gotten good deals on it so thats all i use.
Username: Goose5714
Post Number: 124
I finally got my 50 ft^2 of fatmat, the one layer i put on cut rattling about 75%, throwing 2 more layers on today and i think rattling should be gone...
Username: Terry6405
Sullivan, IN US
Post Number: 316
you cant really get rid of all the rattles,unless you like rhino liner thatshit and dont put the pannels back on.
Username: Redliner
Wilmington, Ma
Post Number: 761
no chauncey i dont have a strong blow dryer but i guess i will be buying something for it is edead v3 hard to put in your whole car
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 83
Amazon.com has pretty good prices on edead, ebay might be cheaper.. oh well..
Username: B101
Queen City, NC USA
Post Number: 1256
Chauncey, you know how much of that edead v3 would it take to do a entire buick lesabre?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11173
charlie: its like ketchup. you mix the two parts and just paint it on. 40 mils thick
B; about 3 gallons.
s for how hard it is.. the most work comes from gutting the entire interior of the car.. taking out the seats, plastic panels, and carpeting etc so the whole inside is bare metal.
