A simple sub ?
Username: Goatin
U.S.A
Post Number: 127
I have 2 15" solo 2ohm DVC L5's that I plan to push with 2 amps my question is can I wire the subs so that I can get 1 ohm from the amp?and if so would it be ok for the sub?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4793
what kind of amps are they, are the 1 ohm stable??
Username: Killer44
Ontario Canada
Post Number: 338
wire the subs in parallel to get a 1 ohm load, the sub will be fine but jsut make sure ur amp is stable at 1 ohm...if i understood ur question rite go with option #1... http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =1&impedance=DVC2x2
