1993 Taurus CD player options
I've got a 1993 Ford Taurus GL 3.0L
Ok so I figured it was about time to stop rocking the tape adapter for all my CD needs and after a little looking and research I figured it would be a safe bet if I bought this. Unfortunately I hate how all non-OEM CD players would look in my car, too much color/lights/etc. So I'd like to stick with something Ford, so I got this.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D5860775380&ssPageName= STRK:MEWN:IT
is this premium sound only? if it is will it be possible to install on my car? Also if its not going to be straight plug and play could I just upgrade completely and get this
http://cgi.ebay.com/ebaymotors/Ford-Premium-CD-Player-Mustang-T-bird-Contour-Mac h-460_W0QQcmdZViewItemQQcategoryZ38641QQitemZ8036338811QQrdZ1QQsspagenameZWDVW
or would that one be even more difficult to install
all help is appreciated also if anyone by chance knows how to get the door panels off my car I'm looking to replace the OEM speakers as well, can get to the rear deck ones fine but the door panels seem like they don't want to budge.
