Which wires??best brand???
Username: Blainew
Post Number: 734
what are the best wires??? power and ground
and what are the best RCA's?
which brand
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4675
All wires are the same
http://www.knukonceptz.com/
^^Nice RCA
Username: Pelona
Post Number: 175
do good rcas increase sq or spl? or do they just reduce the noise the amp makes?
Username: Ruxpin20
DeTroiT, MIchiGan
Post Number: 64
rca's are just there to send the signal to the amp, if you buy bad rca'a then you get bad signal. And visa versa
Username: Kirbdog22
New Bern, North Carolina USA
Post Number: 155
just think of it like this electrons travel thru copper the thicker and shorter the wire is the more amount of electrons can pass thru. so there really is no such thing as nice copper wire it's all the same
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1139
wires are wires
Username: Pelona
Post Number: 180
doesnt a better signal mean you get better sq?
Username: N2audio
Lawrence, Ks USA
Post Number: 423
sure - the thing is - high priced cables don't make the signal any better. They can't, it's just copper transmitting a voltage from the source to the amp. It's really that simple.
