Anybody tested any XX Hifonics amps?
Username: Jprix82
Post Number: 39
Anybody tested any XX Hifonics amps and do they put out their rated power?
Username: B101
Queen City, NC USA
Post Number: 575
SURE
Hifonics XX Zeus (1600 watts & strappable)
Hifonics XX Hercules (2000 watts & strappable)
Hifonics XX Thor (3000 watts & strappable)
Hifonics XX Cyclops (4000 watts & strappable)
Hifonics XX Goliath (5000 watts & strappable)
Username: Jprix82
Post Number: 42
so the XX hifonics put out what they say unlike the brutus series.
Username: B101
Queen City, NC USA
Post Number: 599
You will be very happy!
Especially for the price of that power!
Username: B101
Queen City, NC USA
Post Number: 600
bump;
my threads dont move.
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1159
The only downfall to those amps is how much space they take up...But does the 85% of RMS output apply to these amps as well?
Username: B101
Queen City, NC USA
Post Number: 604
The thing with these hifonics, you will have to give more voltage to get full power. When tested at 12volts they are a little low. Give them 15volts then its a totally different story.
Lower their impedance, then its a totally diffrent story! Man that thing is stable to half ohm! they just dont say it!
Tyler u are sure to see Hifonics at the competitons. Hifonics XX are the Dclass amps.
Username: Jprix82
Post Number: 43
So if i get the Hifonics XX-Colossus II i could push 2 15" Re SX at 1/2 ohm?
Username: Jprix82
Post Number: 44
I mean the Hifonics XX Hercules not the Colossus.
Username: B101
Queen City, NC USA
Post Number: 620
it will be perfect.
to get full power out of the hifonics xx hercules you need to run it less than .7ohms or abit less.
=D
