Like
Bass line driver??
Username: Jprix82
Post Number: 22
Does anybody know what a bass line dviver does and what is its good points and its bad points?
Username: B101
Queen City, NC USA
Post Number: 516
U must mean a regular line driver.
It amplifies the RCA output if you have a weak output from the HU. Some can amplify it up to 8v on the RCAs. Im planing on getting one in a few weeks.
They also have built in Clip LEDs.
It will really make your amp pound!
Username: Insearchofbass
Post Number: 4253
yes its a worth while investment for sure my buddy runs a phoenix gold line driver to his amp they put out 8 volts but are adjustable
Username: B101
Queen City, NC USA
Post Number: 522
yea, you can adjust your output voltage on the RCAs
I need one, cause my HU voltage is only 1.5v!
Ive seen some put out 10v on the output.
Put most amps cant take that much.
I think mine takes up to 8v
Facebook
Shop Related Deals
Directory
