EXTREME rattling problem
Username: Themann
Mt. Holly, NC USA
Post Number: 14
What do you recommend for stopping trunk rattling? My trunk literally jumps up and down the subs hit so hard and it's all you hear outside my car; it's truly embarrassing (but I love it).
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 775
well if you love it dont stop the rattling - haha
Username: Young_james
Post Number: 596
try e-dead, fatman, or some kind of expanding foam works too.......Dynamat is way to expensive and not worth it
Los Angeles, CA USA
Post Number: 1855
you should also find a way to close your trunk tighter. mine was rattling alot too so i got edead and also i put some tape around the metal piece that my trunk hooks on too. that helped alot.
Username: Phuktupbasshead
Scottsdale, Arizona United State...
Post Number: 384
when you say expanding foam...
what kind do you mean...
and WHERE do I spray it?
Under the car, filling up the molding would take 2-3 cans (if not more) just to fill up one corner of the bumper mold!!! Plus, i'm not sure it would even STAY without pouring out or falling out.
I'm totally confused!
Where do I spray it? Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
