OHM loads
Username: Redbone15367
Mo U.S.A.
Post Number: 129
I know how to figure x2 but not diff loads like these. any tell me what these would be?
1.4 + .7 =
.7 + .7 + .7=
1.4 + 1.4 + 1.4=
Thanks
Mo U.S.A.
Post Number: 130
bump, help?
Username: Brynm
Prince Albert, SK Canada
Post Number: 142
for the same values you can cheat and divide by the number of values (.7+.7+.7)/3 = 2.1/3 = .7
three 1.4 ohm loads would be 1.4 a ohm load
for different values
(z1*z2)/(z1+z2) (for you it works out to .466 ohms)
you can use this for as many as you like however do not run two speakers like this! one speaker would be getting about 66% of the power and the other would get 33%, and would sound like crap
Username: B101
Queen City, NC USA
Post Number: 378
the question is NOT clear at all!
but yea, the Product/Sum rule will work!
if he wire them like that he is diffenatley creating a voltage divider rule. LOL
Mo U.S.A.
Post Number: 135
Thanks for the help. The reson for the ? is I have a mt quad.7 and a mt dual .7, that i plan on running just 1 2500d for now. Would like to keep it at .5 or higher.
