Bronze Member Username: KumananPost Number: 23 Registered: Jan-05 | Okay i got two deals here for my two 12'' 1206T audio bahn subs 1. Hifonics BX2200D for $299 Brand new. 2. Orion 2500D REFRUB $355 (ikesound.com) Whichc should i get? I dont want to get a refurb cause im scared it might have a blown channel or messed up some how.. so what should i get. Which is best suitable to push my subs? Is there other options . The subs are 2 ohm each |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4432 Registered: Jul-05 | ORION by a lot, hifonic amps only put out about 70% of there rated power |
Bronze Member Username: KumananPost Number: 24 Registered: Jan-05 | What about The audiobahn A2300HCT or MA HS-802sx.... any other good amp suggestions? Im checking them as you guys post on ebay and i am going to order one, please let me know |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4436 Registered: Jul-05 | The Orion is better than both of those 2. Deirected makes Orion, DEI, and Viper, All are great, Also a Kicker 2500.1 will work, but what are ur vc configs |
Bronze Member Username: KumananPost Number: 26 Registered: Jan-05 | 2 ohm Each sub... so a total 1 ohm load each sub runs 1500 RMS |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4437 Registered: Jul-05 | ^^nope, it would be a 2 ohm load or a 8 ohm load, I think the Viper 2500.1 and the Kicker 2500.1 do 2500 rms @ 2 ohms |
Bronze Member Username: KumananPost Number: 27 Registered: Jan-05 | If theres two subs are 2 OHM each... isnt it 1 OHM load? because two subs at 4 OHM each is a 2 OHM load... |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4445 Registered: Jul-05 | 2 2ohm subs wired in parallel make a 2 ohm load and wired in series makes a 8 ohm load 2 4 ohm subs wired in parallel make a 1 ohm load and wired in series makes a 4 ohm load Nice guide http://www.the12volt.com/caraudio/woofer_configurations.asp |
Bronze Member Username: KumananPost Number: 28 Registered: Jan-05 | your looking at DUAL 4ohm and DUAL 2 ohm Dual 4ohm = 2 ohm. so each sub is 2 ohm Totalling 1 OHM total load.. thats what im getting on the website.. am i incorrect |
Bronze Member Username: KumananPost Number: 29 Registered: Jan-05 | The audiobahns are Dual 4 Ohm each (2ohm each) |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4452 Registered: Jul-05 | ok i see what ur sayin, the website is correct, if u wired 1 of ur subs to an amp it would be a 2 ohm load, but since u have 2 dvc 4ohm subs it will be a 1 ohm load.kk now i understand a amp that does 2500 rms @ 1 ohm is what ur looking for, also i doubt the audiobahns can take there rated power so the 2500 watt amps should work great |
Gold Member Username: TjmutlowPost Number: 1054 Registered: Sep-05 | if you use that orion, you need to supply it with enough power. Alt, battery etc..... |
