Would you reccomend an RE SX??
Username: Blainew
Post Number: 633
these subs recomended??
anything better for the price
i want them loud..but good SQ TOO
Username: Baseball1187
Columbia, SC
Post Number: 509
YES most definitely... they sound good and get reallly loud.
BUT.. if you're looking for a 12, jump on James Longo's ava. In my experiences with both subs, they were equal in output, but the Ava dominated in SQ. Also, the Ava needs less power to get equal results!
Username: Redbone15367
Mo U.S.A.
Post Number: 128
From what I've heard their pretty good, but what size are you looking for?
Username: Blainew
Post Number: 638
12's
Columbia, SC
Post Number: 510
ok, here's what I'd do...
buy James Longo's Avalanche, ported box, tuned to around 30hz (about 2.5 cubes).. get a decent amp (MQ Quart raa1000) and it will beat... and sound good
Username: James1115
Wilton, Ct
Post Number: 4538
If you want loud and SQ then ava is a good choice:-)
