Fatmat good anyone?
Username: Safa19
Post Number: 230
has anyone used fatmat and how does it compare to dynomat? is it the same quality but a cheaper name brand? or is it a cheap knock off that isnt nearly as good as dynomat? easiest way for me to know just rate it 1-10 1 being worst and 10 being best compared to dynomat?
Username: Safa19
Post Number: 234
no good?
Los Angeles, CA USA
Post Number: 1673
i heard good things about it but never used it. i did however use edead which is also much cheaper than dynamat and i like it alot. it did its job.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 3773
Dynomat=7 (use to have it)
Fatman=7 (never used it but from what i heard same as dynomat)
Edead=7 (Chad said it made his system sound much better)
Edead v.3=10 (I have it and its better then dynomat)
Los Angeles, CA USA
Post Number: 1675
damn chauncey why didn't you tell me to get the v3 instead of the v1 i got. lol
Username: Cenus
Hicksville, Ohio Usa
Post Number: 969
were do u find edead, besides ebay.
Post Number: 3774
u already had bought it, plus the v.3 takes a looooonnnnnnnnnnggggggggg time to apply, my bad.lol
Los Angeles, CA USA
Post Number: 1677
thats cool. lol. i am very happy with my edead. it works very well.
just get from ebay. ebay has it for a cheap price.
Post Number: 3778
and u just have it on ur trunk lid right??
Los Angeles, CA USA
Post Number: 1681
yep. when i have time i will to the sides of the trunk as well.
Username: Safa19
Post Number: 236
im looking to do my door panels, trunk, and floor so im thinkin that i will go with the edead v1 because that would be alot to paint on with the v3, the v3 only comes as a liquid right? that is all that i found it for and how much would a gallon do? because that might end up being cheaper cause i have a cavalier which isnt a big car so would 2 gallons do it all or should i get 60sq ft of v1??
Username: Geekbike
Post Number: 411
12 Different mats compared:
http://www.sounddeadenershowdown.com/
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 429
i bought 200sqft of that fatmat extream an i got 4 rools of 18x33.5 ft an i did 3/4 of the trunk an i did the rear deck an sum other places an still didnt use 1 roll yet since i have 3 more rolls ill do the roof ,door panels an the whole sides an the floor how will that b
Post Number: 3913
the sounddeadner showdown is rediculous.lol
Username: Islandboy808
Mililani, Hawaii US
Post Number: 476
buy a product called peel and seal works real good and half the price
Username: Safa19
Post Number: 241
how does fatmat or edead feel under a carpet? like if i was going to do the floor of my car would it feel squooshy or would it just feel the same?
Pgh, Pa Usa
Post Number: 430
it shouldnt the car carpet has all that padden an if u put the sound dead down right in2 the metal an grooves it shouldnt
