I need help anyone who knows about diamond audio
Username: Steven1234
Rahway, NJ
Post Number: 45
ok i wanna know if the 3 way add on S6.omx3 for Diamond audio hex speakers are just the S600 modle only minus the tweeter
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 748
http://www.diamondaudio.com/
alteraudiousa
yesh they are the midrange driver only only does like up to 400hz which is a good candidate for a smaller 5.25 or 4in component set.
Username: Vinnyqh
Portland, OR
Post Number: 142
well the s6.0mx is the 6" woofer and then the crossover for the 3 way, you'll still need the s500s or the s400s (or the s500a / s400a if youwant aluminum tweeter)
