I got an audiobahn a8000t and looking for 2 subs to go with it
Username: Biggyg9712
Post Number: 143
hey, i need to find 2 subs, i got an a8000t which is 800 watts rms, so 400 a sub is good, my budget is around $225, any suggestions?
Username: Islandboy808
Mililani, Hawaii US
Post Number: 398
since u allready have that amp maybe two of these
http://www.crutchfield.com/S-IOeODkXgQts/cgi-bin/ProdView.asp?g=520&I=2065C12VR2
probly can find it on ebay in your price range
Post Number: 144
would this be good
http://cgi.ebay.com/NEW-KICKER-DCVR12-2-12-SUB-ENCLOSED-BOX_W0QQitemZ5847659009Q QcategoryZ32823QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Mililani, Hawaii US
Post Number: 401
no because they are the 4 ohm versions u need the 2 ohm versions to work with that amp
Mililani, Hawaii US
Post Number: 403
try and contact that seller and ask if they charge extra to change out the subs to the 2 ohm subs.
Post Number: 145
i think they are dual 2 ohm subs wired together at 4 ohms. if i put speaker wire from my right sub to my left sub and my left sub to my amp, doesnt that go in as 2 ohms?
Username: Dustin3
Tigard, Or U.S.
Post Number: 213
they arnt already wired. each sub in that box is dual voice coil 4 ohms. you need dual voice coil 2 ohms.
Post Number: 146
it says they r pre-wired to 4-ohms, so im pretty sure they are dual 2 ohm
Mililani, Hawaii US
Post Number: 411
nope^^^
Mililani, Hawaii US
Post Number: 412
with dual 2 ohm subs it can be wired to a .5,2,and 8 ohm independence
and with dual 4 ohm subs it can be wired to 1 or a 4 ohm load
so go figure wich one u need for your amp
Post Number: 147
k, well i found this
http://www.circuitcity.com/rpsm/oid/117529/originURLEncoded/http%253A%252F%252Fw ww.circuitcity.com%252Fccd%252Fcategorylist.do%253Fcmpstr%253D%2526bMore%253D%25 26N%253D20013088%252B21013641%252B40794641%2526No%253D20%2526Ntt%253Dsub%2526Ntk %253DAll%2526catOid%253D-13641%2526link%253Dref%2526PAGE_ACTION%253D%2526c%253D1 /rpem/ccd/productDetailSpecification.do#tabs
it says dual 2 ohms smart one
Username: Dustin3
Tigard, Or U.S.
Post Number: 215
hey mike (smart one) that is a different model. the one on ebay is 05cvr124 and that one it 05cvr122 which means both subs are dual vc 2 ohms. the one on ebay when it says prewired 4 ohms just means that each sub is 4 ohms. they are 2 totally different subs.
Post Number: 148
where does it say the model number on the ebay listing?
Mililani, Hawaii US
Post Number: 415
thats a good match for that amp
Username: Dustin3
Tigard, Or U.S.
Post Number: 222
i just know it. there are a couple of other sub boxes like that one on ebay. and they tell u the model #.
