New member Username: Kevho66Spring, TX United States Post Number: 8 Registered: Nov-05 | I have 2003 Dodge Ram Quad cab with Pioneer 250Watt 6x9's in the doors. Is there any product that will improve the sound quality? Maybe improve the ability of the woofer to maintain a tighter sound that is usually not associated with door spekers. Any suggestions would be great |
Silver Member Username: TjmutlowPost Number: 265 Registered: Sep-05 | is it factory radio, change it and just to let you know, internal speakers are not meant for alot of bass, do not get the factory system confused with anything aftermarket. |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 675 Registered: Oct-04 | If you didn't get an aftermarket HU yet, probably one of those to start. Then maybe some components and an amp. |
Bronze Member Username: Kevho66Spring, TX United States Post Number: 11 Registered: Nov-05 | Sorry...I forgot to mention I have an Alpine CDA-9851 with a Kenwood amp (which I am about to replace. I have heard some good reviews about Dynamat..is it for real? |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 681 Registered: Oct-04 | You can get other stuff for much cheaper, but yes it does work. |
Bronze Member Username: Kevho66Spring, TX United States Post Number: 12 Registered: Nov-05 | what do you recommend? |
Bronze Member Username: LittleguyPost Number: 82 Registered: Dec-04 | B-Quiet Sound Deadening Materials http://www.b-quiet.com/ 877-7-B-QUIET (877-727-8438) |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 687 Registered: Oct-04 | There are tons of companies which make their own sound deadening. Generally you want to use it on spots that rattle. |
Bronze Member Username: Audiowizard69Post Number: 55 Registered: Nov-05 | dyno mat doesnt stick that good. ill tell u what i did in my truck. i bought pillow stuffing from walmart and put it in the doors and it improved my bass. u shouls make sure u put an aftermarket head unit in cuz thats ur main issue. |
