Help with my amp please!!!!!
Username: Audiowizard69
Post Number: 46
I have a 600 watt pyle amp...I know they are not up to par with u all because u have higher standards...so do i but i need to sell this. anyway, 600 watt pyle amp and its a 2 channel. Something is wrong. i hooked it upall was fine for a few days and then last night i turned it on and my left sub made a pause sort of like a bass hit when it came on. I thought nothing of it until i checked the subs when the music was playing... i barely heard sound from the left sub so i un hooked it and put the right channel on it and it sounded fine. i checked all my connections and all were fine. anyone have any idea what this couls be cuz even i am stumped.
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 387
you should check the wiring of the subs also. if thats fine then begin to check every connection w/ your amp. if that is all fine then it could be an internal problem w/ the amp.
Username: Solacedagony
New Jersey US
Post Number: 691
Might have messed up your left channel, if that's the only thing not working.
Post Number: 48
so u think if i rewired everthing it might fix it if its not internal
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 400
yes it's possible and definately worth it just to make sure.
