Silver Member Username: BlainewPost Number: 275 Registered: Nov-05 | i talked to soundstorm ( the brand of my amp) and they said that to adjust my gain...just turn the music up and put the gain to where it sounds good and no distortion..and i said well doesnt it need to be matched to the voltage of the head unit...and he said dont worry about that just put it where there is no distortion is this what i should do...ive heard so much about how u must be careful with the gain.. but will i be okay if i do this... also i have a bass control knob..what should that be set to while adjusting the gain..soundstrom told me 25 %..any other opinions?? |
Silver Member Username: BlainewPost Number: 276 Registered: Nov-05 | meant to post that in amps... |
Gold Member Username: RovinTrinidad & T... Post Number: 3653 Registered: Jul-05 | http://www.bcae1.com/ no. 63 ................... |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1774 Registered: May-05 | step by step: http://mobile.jlaudio.com/support_pages.php?page_id=143 |
Silver Member Username: BlainewPost Number: 277 Registered: Nov-05 | well i figured out a problem that i might have had....i had the loud on...and a bunch of equalizers set..is that why this may be hard to tune?? |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1775 Registered: May-05 | yop. all needs to be flat. |
