1 9500 or 2 w6v2
Username: Kwrubel21
Shelby Township, MI United States
Post Number: 47
1 15" mtx 9500
or
2 12" jl w6v2
the mtx would be getting full power. the w6v2's wouldn't be getting that much due to power issues. unless someone can suggest a nice, cheap amp to power them.
i'm looking for the best deal.
Username: Ford_on_20s
Jacksonville, Florida Us
Post Number: 190
go with the 2 jl w6's.....you dont need to get some nice subs like that and get a cheap amp to power them...you need to get an amp in the same price range or higher to compliment them...like everyone always says around here you get what you pay for
Post Number: 191
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2956
the w6v2's are some of the best subs i ever heard. and like casey said get a good amp, and u will love ur set up
Username: Kwrubel21
Post Number: 48
i already have the 9500. and it sounds pretty nice. and i don't want to spend more then 300 to upgrade it.
if i can trade two 9500's for 2 w6v2's, and buy an amp in the 300 dollar range to power them, then i'll do it. if not, then i'll just have to trade in one of the 9500s for an amp.
Username: Kwrubel21
Post Number: 49
if you guys can find a nice amp, in that price range. i'll most likely do it then.
Post Number: 192
were not saying the 9500 sounds bad....just the w6's will sound better
Post Number: 2959
what kind of amp do u have now
Username: Kwrubel21
Post Number: 50
i'm thinking they'll both be about the same in volume, but the w6's will have much better sq.
Username: Kwrubel21
Post Number: 51
right now i'm running my brothers amp. i've got the one 15" 9500 hooked up to his directed d2400.
but if i go to this place tomorrow, i'd probably get a hifonics brutus 1605.
Post Number: 2962
that amp would work ok with the w6's since it puts out about 1100 rms, but they only really need 800 rms
JL 1000/1
MB Quart ra1000, both would work perfect
Username: Kwrubel21
Post Number: 52
how much is the jl amp going to run me?
Post Number: 2964
500-600 or u might get lucky on ebay and get one around 450's
