Woofer Makes a "HUM" Sound
Username: Tonybones
Post Number: 70
One of my 15" kicker 03cvr15-2ohm woofers have started make a constand hum sound when the volume is decreased but, it isn't noticeable when the volume is increased.What could it be? and whatever it is...can it be fixed?
Username: Josh2027
Devon, United Kingdom
its just background noise i expect. nout to worry about. buy some better phono leads if you want. are you ones at the moment screened or not.
Username: Themax96se
Post Number: 100
Anyone ever use a RCA GROUNG LOOP ISOLATOR:
http://cgi.ebay.com/PAC-SNI-1-RCA-GROUNG-LOOP-ISOLATOR-IN-LINE-NOISE-FILTER_W0QQ itemZ5837835253QQcategoryZ50552QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This may help?
