Speaker Recommendations
Roland
Am looking for high end 6.5" component speakers, but need recommendations on what brand to buy.
I was looking at Focal (165K) and Diamond Audio Hex (S600).
I read the Focals don't emphasize the lows too good and I read a good review on the Diamonds.
I listen to rock, mostly, and like to be able to hear the lows, mids & highs clearly and very defined.
Can anybody recommend any other brands or give me feedback from the above brands?
Derek
Try Morel and Dynaudio. If you want something cheaper, try MB Quart or Infinity Kappa (Car) speakers.
Zeljko
DLS ultimate refference are the best speakers you can buy , but not cheap
adam hutsell
Derek knows his stuff!! Listen to him and u will get far haha. I got kappas, they rock hardcore, but u need an amp for those if u get any of the four he mentioned.
Jof
I would get Focal's with an accurate, not boomy sub. IMO, components are meant to be used with good subs.
I've used Boston Acoustics Pro Series 6.5 components and loved them. They are a very smooth and even set.
