Username: Theceo Post Number: 66 Registered: Apr-05
Monday, November 28, 2005 - 01:52 GMT originally my friend only wanted to spend about 300 on a system, but now hes saying hes willing to spend between 600-800. can you guys suggest sum good subs and amps? he has a stock cd deck, he says he doesnt want to change that, but im trying to talk him into it.
Username: Bestmankind Los Angeles,
CA
Post Number: 1017 Registered: Oct-05
Monday, November 28, 2005 - 01:56 GMT does he want a spl system or sq system.
Username: Theceo Post Number: 68 Registered: Apr-05
Monday, November 28, 2005 - 01:58 GMT i dont know what spl or sq means, but im guessing your talking about bass vs sound quality. he wants it to be more about bass, but at the same time he still wants good sound quality. but yea hes wanting the bass over the sq.
CA
Post Number: 1018 Registered: Oct-05
Monday, November 28, 2005 - 02:04 GMT subs...2 12" re se or 2 12" alpine type r amp....orion-1200d or kicker kx1200.1 for a budget of 600-800 dollars those would be my choices.
Username: Baseball1187 Columbia,
SC
Post Number: 212 Registered: Dec-04
Monday, November 28, 2005 - 02:05 GMT I would say stick below around 600w RMS if he's keeping the stock alternator. What kind of room are we talking about? does he want 10,12,15? 1 or 2?
Username: Theceo Post Number: 69 Registered: Apr-05
Monday, November 28, 2005 - 02:09 GMT he wants to 12s in his trunk.
SC
Post Number: 213 Registered: Dec-04
Monday, November 28, 2005 - 02:11 GMT well, what Chad said would be a good choice... but he'll want to consider upgrading his charging system, not a capacitor...
Username: Rhassler Gilford,
NH
Post Number: 439 Registered: Dec-04
Monday, November 28, 2005 - 02:14 GMT you could do 2 12" kicker comp VR's and an orion 600d. One of my friends did that, it gets pretty loud and sounds good.
Username: Theceo Post Number: 70 Registered: Apr-05
Monday, November 28, 2005 - 02:14 GMT what do you mean his charging system, like his alternator? and its now like he has sum little civic or anything, hes got a 2002 grand prix gtp, but i dont know what kinda alternator that has.
SC
Post Number: 214 Registered: Dec-04
Monday, November 28, 2005 - 02:19 GMT the kx1200.1 will draw over 100amps at RMS .. That is probably about what his alternator puts out, it leaves no room to run his car...
Username: Theceo Post Number: 71 Registered: Apr-05
Monday, November 28, 2005 - 17:38 GMT hmm...ic ic, and how much would a better alternator cost, do you know?
Username: Theceo Post Number: 72 Registered: Apr-05
Monday, November 28, 2005 - 17:56 GMT bump
SC
Post Number: 216 Registered: Dec-04
Monday, November 28, 2005 - 23:48 GMT anywhere from $200 up. Probably around $300 for an alt that puts out around 200amps which is about what you'd need.
Username: B101 Queen City,
NC
Post Number: 95 Registered: Sep-05
Tuesday, November 29, 2005 - 00:45 GMT the 3.8 engines come with a 105 amp alternator, may have an optional 120 amp. thats if he has the big package. I love those engines.... He needs like 200 amps atleast!!
