Kicker
Username: Drummer_boy
Franklinton, Louisiana USA
Post Number: 11
My freind has a Chevy Sliveroda with the bed cut out to fit 4 L7 i told him he should just put 2 Solo X's in it, what do you think he should do
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 320
either one would be loud if your not concerned w/ sq i would say get the 4 it will look a little cooler. if he's goin for show 4 subs would look better than 2.
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 246
The 4 L7s will be superior in output, easier to power, and look cooler. If he doesn't plan on burning up and rebuilding subs at every comp stick to the L7's.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2016
i have 4 l7's.lol
Username: Trippinbarr
I was wondering if anybody knew where to find the spec to build a ported L7 speaker box
Username: Mobster
kicker.com or the L7 manual. i need help with mine i have 2 12" L7's and it isnt too loud
Post Number: 2301
willy what kind of amp do u have
Username: Mobster
kicker 1200.1 but i had 2 10" L7's before the 12's and i traded them in for the 12's
Post Number: 2302
what kind of box do u have, and do u have a HO alternator
Username: Mobster
lol its sealed and definatly not to reccomended specs and i dont knwo what a HO alternator is?
(i am going to build a ported box soon. lol thats what ive been saying for a while i just dont know the specs)
Post Number: 2307
thats it then, ur amp can not draw enough current from ur alternator, and building ur box to recommend specs would help alot as well.btw i have 4 15 l7's and there are plenty loud
Username: Mobster
man that must be so loud. have u entered any comps? and where would i get a high output alternator and i have a 1999 Subaru Outback and i donno how to build a ported box to fit my car. lol im a newb
Post Number: 2310
no comps
http://www.excessiveamperage.com/
They make great alternators, just give them a call
http://www.klausaudio.com/
Great boxes
Username: Mobster
my car hatch rattles alot and i dont want to buy dynamat . how do i "lessen" the rattling. also ive given up on sound quality so what "tricks" are there for SPL??
Post Number: 2313
i used edead v3 and it works great, almost no rattle at all. And im not sure of any "tricks" for spl.lol
Username: Mobster
Post Number: 8
could i get that off eBay . i live in C a nada. lol
Post Number: 2320
yep
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1669
peal-n-seal...its really cheap and you can get it at Lowes. or get edead.
also, if you have a hatchback...try a CRX box (ex: subs firing up, ports back) and always test, test, test.
Username: Mobster
Post Number: 9
peal-n-seal would it work as good as like eDead or dynamat? and so i was thinking subs firing towards the roof then have the port exit facing the hatch.
Username: Mobster
Post Number: 14
ok i live in canada and so what hardware store would sell that peal-n-seal????????
