Hi little help from Glasswolf
Username: Hostage
I have been reading the threads and notcied Glasswolf knows what hes talking about :D... My Question is I have a Kenwood KAC-929 Amp and 2 10" Kenwood subs, and 2-ohm stability
how can i wire everything properly??
And also i was thinking about Phoenix Gold Subs 10" would this amp do the job? and what kind of PG subs would you prefer, or is there anything else higher quality?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2536
ideally, to get the full 230wRMS x 2 from the amp with two subs, you need each sub to be 2 ohms, or 4+4 ohm DVC with coils in parallel, one sub per channel.
I don't know the coil configuration of your 10" subs so that's all the info I can offer
Username: Hostage
Sorry i forgot to put the specs of the sub here they are...
Key Features
- Maximum Input Power: 300W + 300W
- Rated Input Power: 75W + 75W
- 10" Tornado-Type Silver Pearl Mica Injection-Molded Polypropylene Woofer
- Extended Pole Piece For Large Xmax
- Gold Plated 2-Way Screw Bind Input Terminals
- 1-Year Warranty
General Features
- Frequency Response: 28Hz-800Hz
- Sensitivity: 91dB
- Impedance: 4 Ohm + 4 Ohm
- Canadian M.S.R.P. $189.99 (Manufacturer Suggested Retail Price)
- Authorized Kenwood Dealers May Sell For Less
Username: Glasswolf
Post Number: 2542
hmm
ok wire coils in parallel (+ to + and - to - on the two pair of coils) and put one sub on each channel.
they're only rated for 150wRMS each, total, and you'll get ~230wRMS each from that amp so if they start to bottom out, don't turn it up so loud..
just be careful and you should be fine
Username: Hostage
My friend has a pair of Alpine type S in a sealed box for sale $400 Canadian will the 230w power per channel cut it?? and would it pound or get a better amp?
Username: Glasswolf
Post Number: 2571
you can do better.. hell you can buy type R 12" subs for $120-150 US each, and build a good box for $40 in hardware.
