Silver Member Username: BlainewPost Number: 108 Registered: Nov-05 | i know i keep posting about the L7's but this is it.. 2 12 inch l7's with a 2500.1 amp from kicker.. what kind of box..in a jeep cherokee..ported or sealed..i want them loud..and if ported what frequency..thanks for all the help and one more thing how much does one 12L7 weigh?? |
Bronze Member Username: Subman15Lwarenceburg, Kentucky United states Post Number: 84 Registered: Nov-05 | shipping wieght is 20 lbs. the tuning frequencey should be in the manual, you can download it off kicker.com |
Bronze Member Username: FrkkevinFort Worth, Texas US Post Number: 51 Registered: Nov-05 | Ported will be the louder option. Most of the people I know who run them tune the ports to 33hz but I'm not sure what the specs recommend. Your best bet s to do what alex recommended and look in the manual. |
Bronze Member Username: Subman15Lwarenceburg, Kentucky United states Post Number: 88 Registered: Nov-05 | http://www.kicker.com/05/tech-support/manuals/manuals/04Solo%20Baric%20L7%20Subw oofer%20Manual.pdf here is the manual |
Silver Member Username: BestmankindLos Angeles, CA USA Post Number: 950 Registered: Oct-05 | yeah go ported. |
Silver Member Username: BlainewPost Number: 109 Registered: Nov-05 | how do u "tune" the box??? |
Bronze Member Username: Subman15Lwarenceburg, Kentucky United states Post Number: 89 Registered: Nov-05 | thats pretty funny chad |
Bronze Member Username: Subman15Lwarenceburg, Kentucky United states Post Number: 90 Registered: Nov-05 | http://www.carstereo.com/help/Articles.cfm?id=31 this site tells you what size to make the port. tuning a port is mainly the size of it |
Silver Member Username: BestmankindLos Angeles, CA USA Post Number: 957 Registered: Oct-05 | i got that picture from chauncey. lol |
Silver Member Username: BlainewPost Number: 110 Registered: Nov-05 | on the manual it shows how to wire a single to get all the different ohms...but then how would i wire it with 2 subs?? |
Silver Member Username: BlainewPost Number: 112 Registered: Nov-05 | actualy...you would just wire the subs to however many ohms each u want them...like if its a dual 4 ohm...u wire each sub to 8 ohms..and then the plus and minus wire ..u treat that just the same as if the sub was a single voice coil 8 ohm sub..and then just wire both subs together in paralell right?? |
Silver Member Username: Subman15Lwarenceburg, Kentucky United states Post Number: 118 Registered: Nov-05 | http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html this will show you how to wire multiple subs |
Silver Member Username: BlainewPost Number: 114 Registered: Nov-05 | perfect thank u |
Gold Member Username: RovinTrinidad & T... Post Number: 3132 Registered: Jul-05 | http://www.the12volt.com/caraudio/woofer_configurations.asp |
