1 12" SX vs 2 12" type R's
Username: Thigpen
RVA, Va Usa
Post Number: 286
how is the sound quality on the SX's. would it be better or worse than 2 type R's, and would it be louder?
Username: Baseball1187
Columbia, SC
Post Number: 192
the SX has pretty good SQ. I can't directly compare it to the type R though. If you want SQL you can't go wrong with either. the 2 12" type R's would have the advantage in SPL though over a single SX. 2 SX would be louder though with the the right power and setup
Los Angeles, CA USA
Post Number: 666
from what i read on this forum the sx can get really loud if you build the right box.
Username: Rovin
Trinidad & T...
Post Number: 2803
everybody get far away from Chad cause of his post number above -lol
UploadUpload
Los Angeles, CA USA
Post Number: 668
lol. i didn't even notice that.
that is disgusting rovin.
Username: Suleman36
Maryland U.S.A.
Post Number: 2642
I whould take the 2 12 type R's because overall it has the potential to get louder and sound alot better SQ wise and take the same amount of power or less then the SX
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 771
2 12" type r's can get rediculously loud imo.. i just finished a ported box for my friend hes got an explorer.. its so loud you almost cant stand it.. his roof flexes a good inch and a half lol
Username: Subman15
Lwarenceburg, Kentucky United states
Post Number: 52
how would an 18" sx compare to the alpines?
Los Angeles, CA USA
Post Number: 687
what is the cu ft of the ported box you built. and also what did you tune it to. i am looking to build a ported box for my Rs.
Username: Rzarector
Post Number: 772
it was just over 2 cu ft per chamber tuned to around 36 hz
Los Angeles, CA USA
Post Number: 696
i had them in a 1.7 cu ft per chamber box with a slot port until i changed it to a 1.25 sealed. i like the sealed better probably cause the ported box i had was a poor design. i don't even know what it was tuned to cause the place that sold it to me said "huh" when i asked what is it tuned to.
Username: Rzarector
Post Number: 773
lol
with your chambers are you guyings having a piece of wood seperating chambers?
