Rockford Fosgate T212D2 DVC 2 ohm
Username: Kirbdog22
I am a illiterate when it comes to car audio first of all. I would like to know if I was going to purchase the subwoofer listed above if the anp that should go with it would be one that could run 1000W RMS @ 2 ohm? What type of gauge wiring would I need and recommended box?
Username: Araknid
BOCA , FL U.S.
Post Number: 1195
A DVC 2 ohm sub can be wired to a 1 ohm load in parallel or a 4 ohm load in series.
Username: Araknid
BOCA , FL U.S.
Post Number: 1196
The sub is 1000 watts RMS so you would need an amp that puts out 1000 watts RMS at 1 ohm or 4 ohm.
Username: Kirbdog22
What does it mean to wire and amp to a 1 ohm load in parallel or a 4 ohm load in Series?
Username: Kirbdog22
Why not just get one that runs at 1000W at 2 ohms?
Username: Kirbdog22
Thank you for the help
Username: Araknid
BOCA , FL U.S.
Post Number: 1197
The gauge of the wire would depend on the current draw of the amp.
And 1.5 cubic feet for a ported box.
http://www.speedsound.com/caraudio.asp?pg=products&specific=jngmgqnoo
doesnt say anything about sealed but im guessing around 1.1 cubic feet.
Username: Araknid
BOCA , FL U.S.
Post Number: 1198
A DVC 2 ohm can only be wired to 1 ohm or 4 ohm thats just the way it is.
Username: Kirbdog22
Alright i understand, but why would they (Rockford) say impedeance 2 ohms i just don't get it, i look online to find and amp that matches up with that.
Username: Kirbdog22
appreciate the help i have learned much more
Username: Araknid
BOCA , FL U.S.
Post Number: 1199
ok check it out. DVC means dual voice coil. Each coil has a impendance of 2 ohms for your sub. In series the impendances of the coils are added together so series would be 4 ohm. In parallel the impendance becomes half of one of the coils. So in parallel it would be 1 ohm.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 678
a dvc 2ohm sub means each voice coil is 2ohms so when wired in parrell it makes a 1ohm load and when wired in series it makes a 4ohm load. and 2 good amps to power that sub would be kicker kx1200.1 or RE 12.1
Username: Kirbdog22
New Bern, North Carolina USA
Post Number: 7
ah now i get it thanks man
Username: Cenus
Post Number: 679
damn u beat me buy a minute.
Username: Araknid
BOCA , FL U.S.
Post Number: 1200
This is helpful http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Just imput the info. In your case 1 sub and DVC 2 ohm and it will show you diagrams of the possible ways to wire it.
Username: Kirbdog22
Post Number: 8
So which amp would you select one that pushes 1000W @ 4 ohms or one that pushes 1000W @ 1 ohm?
Username: Cenus
Post Number: 680
how much do u want to spend, the RE 12.1 sells for 390 shipped, which would make a perfect amp for that sub.
Username: Araknid
BOCA , FL U.S.
Post Number: 1201
It would be much cheaper to get the amp to run for 1 ohm.
Username: Kirbdog22
Post Number: 9
what is the RE 12.1?
any others besides that?
Username: Kirbdog22
Post Number: 10
If i get and amp that runs at 1 ohm doen't that kind of put some stress on the amp?
Username: Araknid
BOCA , FL U.S.
Post Number: 1202
No it will say on the specs if it is 1 ohm stable or not. If it is then thats what it was designed for.
Username: Kirbdog22
Post Number: 11
So look for and amp that can run at 1000W @ 1 ohm stable.
Username: Araknid
BOCA , FL U.S.
Post Number: 1203
Yup. Your getting one sub right?
Username: Cenus
Post Number: 682
http://www.reaudio.com/html/amps.htm thats the RE 12.1, kx1200.1,sx1250.1,
Username: Kirbdog22
Post Number: 13
yes just one
Username: Araknid
BOCA , FL U.S.
Post Number: 1204
puts out an extra 200 watts but should work nicely.
Username: Kirbdog22
Post Number: 15
where could i get this amp online? price?
Username: Araknid
BOCA , FL U.S.
Post Number: 1206
390 shipped and directly from REaudio.
Username: Araknid
BOCA , FL U.S.
Post Number: 1207
Resonant Engineering HQ
781 Middlegate Road
Henderson,
NV 89015
em - sales@reaudio.com
em - tech@reaudio.com
tel : (702) 896 4823
